Arnold crashing many times
pawel_karbarz
pawel_karbarz
I've got a simple scene, build from scratch (studio setting). I'm merge some 3d object from another scene (made in 3ds max) and textures (base color, orm, normal, sometimes opacity or emission) made in substance painter. I'm using default parameters in Arnold settings, just increase Camera AA to 5 and toggle on Global Light sampling. I'm using HDR map, 4 Arnold lights (point, 2x square, 1 disc) and Arnold camera. No other render pass or different features. How can I check what is the problem of the crashing (some logs, etc). I'm using newest version of 3ds max 2026.1 with updated yesterday MAXtoA 5.8.2.1
pawel_karbarz
FILE_IN_CAB:  3dsmax_minidump.dmp
NTGLOBALFLAG:  0
CONTEXT:  (.ecxr)rax=0000000000000000 rbx=00000048d17eec60 rcx=00000273a62ff640
rdx=000000003f750a34 rsi=00000273a62ff100 rdi=00000048d17eeed8
rip=00007ffd55773069 rsp=00000048d17eec08 rbp=00000048d17eecb0
 r8=3f7674163f75c890  r9=00000273a62ff6f8 r10=00007ffe23240000
r11=0000000000000000 r12=0000000000000000 r13=00000048d17ef8c0
r14=00000273a62ff640 r15=00000048d17ef6a0
iopl=0         nv up ei ng nz ac pe cy
cs=0033  ss=002b  ds=002b  es=002b  fs=0053  gs=002b             efl=00010293
ai+0xaa3069:
00007ffd`55773069 4d8b5020        mov     r10,qword ptr [r8+20h] ds:3f767416`3f75c8b0=????????????????
Resetting default scope
EXCEPTION_RECORD:  (.exr -1)ExceptionAddress: 00007ffd55773069 (ai+0x0000000000aa3069)
   ExceptionCode: c0000005 (Access violation)
  ExceptionFlags: 00000000
NumberParameters: 2
   Parameter[0]: 0000000000000000
   Parameter[1]: ffffffffffffffff
Attempt to read from address ffffffffffffffff
PROCESS_NAME:  3dsmax.exe
READ_ADDRESS:  ffffffffffffffff
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%p referenced memory at 0x%p. The memory could not be %s.
EXCEPTION_CODE_STR:  c0000005
EXCEPTION_PARAMETER1:  0000000000000000
EXCEPTION_PARAMETER2:  ffffffffffffffff
IP_ON_STACK:
+0
00000048`d17eec60 47              ???
FRAME_ONE_INVALID: 1
STACK_TEXT:
00000048`d17eec08 00000048`d17eec60     : 00000048`d17eecb0 00000048`d17eeed8 00000273`a62ff100 00007ffd`555baf68 : ai+0xaa3069
00000048`d17eec10 00000048`d17eecb0     : 00000048`d17eeed8 00000273`a62ff100 00007ffd`555baf68 00000230`4415af00 : 0x00000048`d17eec60
00000048`d17eec18 00000048`d17eeed8     : 00000273`a62ff100 00007ffd`555baf68 00000230`4415af00 00007ffd`55917910 : 0x00000048`d17eecb0
00000048`d17eec20 00000273`a62ff100     : 00007ffd`555baf68 00000230`4415af00 00007ffd`55917910 429a1433`41bb1888 : 0x00000048`d17eeed8
00000048`d17eec28 00007ffd`555baf68     : 00000230`4415af00 00007ffd`55917910 429a1433`41bb1888 41bb1888`425871b6 : 0x00000273`a62ff100
00000048`d17eec30 00000230`4415af00     : 00007ffd`55917910 429a1433`41bb1888 41bb1888`425871b6 00000000`00000000 : ai+0x8eaf68
00000048`d17eec38 00007ffd`55917910     : 429a1433`41bb1888 41bb1888`425871b6 00000000`00000000 00000271`8f551000 : 0x00000230`4415af00
00000048`d17eec40 429a1433`41bb1888     : 41bb1888`425871b6 00000000`00000000 00000271`8f551000 42e7b32d`c4134847 : ai+0xc47910
00000048`d17eec48 41bb1888`425871b6     : 00000000`00000000 00000271`8f551000 42e7b32d`c4134847 3f7b240a`440d557f : 0x429a1433`41bb1888
00000048`d17eec50 00000000`00000000     : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x41bb1888`425871b6
SYMBOL_NAME:  ai+aa3069
MODULE_NAME: ai
IMAGE_NAME:  ai.dll
STACK_COMMAND: ~284s; .ecxr ; kb
FAILURE_BUCKET_ID:  INVALID_POINTER_READ_c0000005_ai.dll!Unknown
OS_VERSION:  10.0.19041.1
BUILDLAB_STR:  vb_release
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
IMAGE_VERSION:  7.4.2.1
FAILURE_ID_HASH:  {f4556e40-acb9-7fa6-3b02-76a1e6af0a59}
Followup:     MachineOwner
This is a minidump from last crash. I think the problem is denoiser in this case (I'm going to change from default to OptiX and check again).
pawel_karbarz
I test this a little bit and Max stop crashing, it's probably problem with denoiser, OptiX crash just once for now in very long run. So, problem solved.
