3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
Arnold bake to texture using normal map creating artifacts
1 REPLY 1
paperthinportal
753 Views, 1 Reply
paperthinportal
My bake to texture render output is creating artifacts when a normal map is used. Software is Max 2022 with Arnold 4.3.4.12. I do not see anything strange in the normal map itself. Baking without a normal removes artifacts. There are no overlapping UV's or polygons in these areas.
Things I've tried:
  • New default Arnold surface using only a normal
  • Increasing ray counts using various combos of diffuse/specular/camera values
  • Removing the environment map
  • Trying various AA mode types (Gaussian, Mitchnell etc)
Things I've tried:
1 REPLY 1
paperthinportal
Well, found an odd fix. I scaled up the model 0.1% on the Y axis and that somehow reset some type of information in the mesh, now the artifacts don't show up.
