The issue I have is there is an extended pause after each frame I render. I am rendering locally to a hard drive. I have tried rendering to different image formats and I have tried not writing to a file at all. The render buffer just hangs for a while. The pause is longer than the render itself. Using Arnold.
Suggestions appreciated.
Solved by FHull. Go to Solution.
Hard to say without a log. Are you saving AOVs? That pause is probably 3ds Max saving the frame, and if is a big file, it could take some time. How long does pause takes? Can you also attached a log?
@CiroCardoso3v wrote:That pause is probably 3ds Max saving the frame, and if is a big file, it could take some time.
It would take more time to save as smaller file...
In any case shouldn't be noticeable.
Apparently the issue was unresolved X-refs. I couldn't remove the xref records so I merged into a new scene and the problem went away. I can understand why missing xrefs might slow down the beginning of a render - attempts to locate the missing resources - but not after the render has already completed!
