Hi everyone, im currently facing a problem of having rendered with white background and black object as an outcome of my furniture.
I totally have no idea what is going on. Does anyone know what problem is this?
Solved by Francisco_Penaloza. Go to Solution.
Read the manual of your render engine. Your problem is exposure. Ther is too much light in your scene.
Thanks!!
May I know what is the problem of having a dark background after rendering though i have put vray light and photometric light?
I don't understand the question.
Are you asking if there is a problem to render an object with a black background? or why are you getting a black background??
I may guess you are very new to rendering using 3D Max.
If this is the case I will recommend reading the help documents that comes with the software, there you can find information on how the software works, and how to setup basics scenes.
You could also search online for a tutorial of studio or product rendering setup.
You should take the settings with a pint of salt thou because there is not a magic number for them, and they will vary depending on your scene, but the overall workflow and how to properly setup lighting and camera are well explained in many tutorials.
best luck.
thanks for your suggestions!
My previous question is after i place the lighting and rendering, the background image is dark and nothing to show up.
