3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
3ds max 2018 Take long time to Save & Merge
16 REPLIES 16
Message 1 of 17
patelpankaj193
12934 Views, 16 Replies
If i merge a object from different good file then it take to long to merge object also autosave and manually save take to much time.
dont know whats happining
file is totally clean
using Cleaner So no NoteTracks Or AnimationLayer
Please help
truly getting Frustrate!!!!!!!!!
16 REPLIES 16
Message 2 of 17
in reply to: patelpankaj193
i have the same problem
did you manage to find solution?
Message 3 of 17
Here, too, is the same problem. I noticed that when I do merge the MAX automatically saves the file that I am working with and adds a backup extension. What should it be?
Message 4 of 17
Hi
I think i sort out my problem
I found that some motion cleaner/ cleaner script out there dont complete clean or see all the nodes in the file
and the autodesk's one clean much better and now my file is working fine now
https://area.autodesk.com/blogs/max-station/n49_overly_large_max_files_or_scenes_that_take_up_a_lot_...
Many thanks
H
Message 5 of 17
Thank you so much!! after testing 1000 ways to fix the problem finaly your post gave me the solution....
I had the problem that my files took to long to open and i had to wait 10 minutes to merge a 3 mb file in to my scene....but after runing the script its every think fine. thanks ....
Message 6 of 17
Thanks Man, I can't believe, it resolved.
Message 7 of 17
Nicolas.pojmaevich
Hi, thanks so much for this!!, i was going mental not knowing what was happening, you save me.
Message 8 of 17
I still have the same problem even in 3ds max 2020, any solution?
Message 9 of 17
It really worked like miracle. Thanks a lot!!!
Message 10 of 17
same problem bro. plz help me i using 3ds max 2014 plz give e solution !
Message 11 of 17
Waseem_Dabbas
Prune scene script solved the problem for me
Just download it from here
https://github.com/3DGROUND/Prune-Scene/blob/master/PruneScene.mzp?raw=true
It will give you a yellow icon in the 3ds max main tool bar, click 1,2,3, clean everything (or uncheck some unwanted things like missing material and memory)  then click on 'start' now your file is ready to merge and use quickly.
Thanks to my friend 'Muayed' who teach me this method.
Message 12 of 17
patelpankaj193
use script mentoned
Message 13 of 17
jason
in reply to: Waseem_Dabbas
Prune Scene script above also worked for me. Long save times. Long merge times (even for simple geo). It was cutting into my productivity big time. I was so thankful that I'm going to PayPal the developer.
Message 14 of 17
renderhaus
Henryyu12, Would you mind posting a current link to the tool you originally referenced (linked) in your 3-22-2018 post?  The link you provided then is just taking me to the splash page for Autodesk Area.
Thanks much!
Message 15 of 17
t=trackviewnodes;n=t[#Anim_Layer_Control_Manager];deleteTrackViewController t n.controller;gc()
run this script and press right side numeric "Enter"
Save on desktop and run once in while for every scene
You can also download "Prune Scene" for completely clean, Virus, and ALC removal
Message 16 of 17
patelpankaj193
in reply to: renderhaus
Message 17 of 17
renderhaus
Perfect!  Thanks patelpankaj193
Technology Administrators
