3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
3ds max 2017 vray render problem
10 REPLIES 10
Message 1 of 11
6102 Views, 10 Replies
Hello everyone, im new in using vray , and i have a big problem ! When i try render my scene ,ends up white , what may cause that problem ? It tells me as a warning : the scene is too far from the original and may cause problem with rays . Is this the reason it turns out white? Thank you
10 REPLIES 10
Message 2 of 11
@Anonymous
 open ( Environment and effect by click on 8 ) and change Exposure control to vray exposure control ,If it did't work attach your file to check it .1.png
@Anonymous
Message 3 of 11
Hi and thank you for answering! i cant attach my file here because its private, this with the exposure didnt work out 😕 Before using Vray , i used to using mental ray. Is there any settings that i should have change and maybe thats why it doesn't work ? Also i have put vray sun, vray materials, is there something missing for a complete render? Just tell me what should i looking for because im lost, thank you ! 🙂
Message 4 of 11
Hello !@Anonymous
Ok no problem , can you attach  screen shots for render settings window and (environment & effect )?
Hello !@Anonymous
Message 5 of 11
rendermaster
rendermaster
along with vray exposure stated above, if you are using vray....your material should be vray also. and for the lights settings, you need to choose vray shadow.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Message 6 of 11
jamesw
jamesw
Try adjusting the exposure. The scene may be over exposed.
Message 7 of 11
Well i just noticed that the white scene appears only when i use the physical camera. When i have top view without camera it seems normal now, except some objects that doesnt appear at all, why is that?
Message 8 of 11
jamesw
jamesw
Physical camera has its own exposure control under the camera settings.
Message 9 of 11
in reply to: jamesw
Ok thank you i will check it ! What about the objects that dont appear at all in the render frame buffer?
Message 10 of 11
renderingbproblem
SHOP.jpgcloud type texture all the time i render an image what can i do ?
renderingbproblem
Message 11 of 11
basakbc007
basakbc007
thanks a lot a@hmed
thanks a lot a@hmed
