3ds Max Shading, Lighting and Rendering
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max materials topics.
3D Studio Max with radeon?
2 REPLIES 2
2541 Views, 2 Replies
hi
i buy a new video card  Radeon r9 270x dual 4gb
and i want to know if the 3DS can render with the r9 gpu?
i need to config something?
2 REPLIES 2
Steve_Curley
If you mean work with the Hardware Renderers in Max (Iray, Quicksilver) then probably not. They require CUDA cards which AFAIK means nVidia only.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
eodeo
iray will work with CPU only, but its much faster with an nvidia GPU in the class of 270x, like 660 or 760.
Max and quicksilver will both work fine with 270x, but they both prefer nvidia gpu. Reversing the situation in games, 660 is faster in Max by about 20%- in quicksilver. Difference in Max viewports is not that noticeable.
If you don't intend to use iray and you don't care that QS is slower, go for the AMD card. Just make sure you also are using a single monitor or that you don't care about triple power usage when using AMD card with two or more monitors.
