hi
i buy a new video card Radeon r9 270x dual 4gb
and i want to know if the 3DS can render with the r9 gpu?
i need to config something?
Solved by eodeo. Go to Solution.
iray will work with CPU only, but its much faster with an nvidia GPU in the class of 270x, like 660 or 760.
Max and quicksilver will both work fine with 270x, but they both prefer nvidia gpu. Reversing the situation in games, 660 is faster in Max by about 20%- in quicksilver. Difference in Max viewports is not that noticeable.
If you don't intend to use iray and you don't care that QS is slower, go for the AMD card. Just make sure you also are using a single monitor or that you don't care about triple power usage when using AMD card with two or more monitors.
