3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Sliced object and selection
2 REPLIES 2
elpie89
354 Views, 2 Replies
Hi, I'm trying to identify a proper way to detect the resulted part of a slice plane
a GIF is probably more understandable.
How can identify the split parts trough max script?
Tags (1)
2 REPLIES 2
denisT.MaxDoctor
in reply to: elpie89
The answer looks obvious - it's the faces above and below the slice plane.
Check all triangle centers in the slice plane coordinate system. If z of the center's position is positive, the face is above; if it is negative, then the face is below.
klvnk
in reply to: denisT.MaxDoctor
if using editable poly IIRC polygons below have bit 17 set in face flags
polyop.setFaceSelection $ (polyop.getFacesByFlag $ 65536)
should select all faces below a slice
