Script rendering with gamma setting
kenc
kenc
Hi All
I have a script that is rendering unwraps using the following script line
bake_map = render rendertype:#bakeSelected outputSize:[1024, 1024]  vfb:off outputfile:(LightBakeMap_png_name) gamma:1.0
but the saved image doesn't look any different than using gamma:2.2
Thanks in advance
senorpablo
Max gamma settings are all over the place. Perhaps the gamma setting in that code is for the file only, not the rendering.
Try this before your code:
IDisplayGamma.colorCorrectionMode = #gamma
IDisplayGamma.gamma = 1.0
kenc
Thanks senorpablo
The gamma in the code is for the saved image. Actually it turned out to be another causing the saved images to be the same.
I will look into the two commands you suggested.
senorpablo
There is also:
fileOutGamma=1.0
