import pymxs from PySide2 import QtCore from PySide2 import QtWidgets import MaxPlus class PyMaxDialog(QtWidgets.QDialog): def __init__(self, parent=MaxPlus.GetQMaxMainWindow()): super(PyMaxDialog, self).__init__(parent) self.setWindowTitle('Pyside Qt Window') self.initUI() def initUI(self): self.main_layout = QtWidgets.QVBoxLayout() self.label = QtWidgets.QLabel("Click button delete this text") self.main_layout.addWidget(self.label) delete_btn = QtWidgets.QPushButton("Delete") delete_btn.clicked.connect(self.remove_text) self.main_layout.addWidget(delete_btn) self.setLayout(self.main_layout) self.resize(250, 100) @QtCore.Slot() def remove_text(self): self.main_layout.removeWidget(self.label) pymxs.runtime.RedrawViews() def main(): w = PyMaxDialog() w.show() if __name__ == '__main__': main()
execute this code and click on the Delete button.
those are before/ and after images
Is this normal?
for me, this looks like a bug
I tested this in max 2019 on two different machine
