remove widget bug
remove widget bug
elpie89
remove widget bug
elpie89
import pymxs
from PySide2 import QtCore
from PySide2 import QtWidgets
import MaxPlus
class PyMaxDialog(QtWidgets.QDialog):
	def __init__(self, parent=MaxPlus.GetQMaxMainWindow()):
		super(PyMaxDialog, self).__init__(parent)
		self.setWindowTitle('Pyside Qt Window')
		self.initUI()
	def initUI(self):
		self.main_layout = QtWidgets.QVBoxLayout()
		self.label = QtWidgets.QLabel("Click button delete this text")
		self.main_layout.addWidget(self.label)
		delete_btn = QtWidgets.QPushButton("Delete")
		delete_btn.clicked.connect(self.remove_text)
		self.main_layout.addWidget(delete_btn)
		self.setLayout(self.main_layout)
		self.resize(250, 100)
	@QtCore.Slot()
	def remove_text(self):
		self.main_layout.removeWidget(self.label)
		pymxs.runtime.RedrawViews()
def main():
	w = PyMaxDialog()
	w.show()
if __name__ == '__main__':
	main()
execute this code and click on the Delete button.
those are before/ and after images
3ae58377aceda5603b00c758bd355b519df877d0.png7f4a2d4c1b1f48166f9e93a870d14ac7b42d25cc.png
Is this normal?
for me, this looks like a bug
I tested this in max 2019 on two different machine
drew_avis
I see the same thing on 2020.  However, I think this is expected PySide behaviour, not a bug, and other people see the same thing in non-3ds Max apps, eg:
https://stackoverflow.com/questions/9899409/pyside-removing-a-widget-from-a-layout
It looks like once you call removeWidget(), you are now responsible for deleting that widget (the layout no longer owns it).
I was able to fix your example by changing remove_text() to this:
	@QtCore.Slot()
		self.label.deleteLater()
		self.update()
Hope that helps,
Drew
Drew Avis
Content Experience Designer
elpie89
ok I didn't try with the deleteLater method
I used instead
self.label.hide()
del(self.label)
It worked as well, anyway the default behavior is strange
Anyway, problem solved.
