Hello
I have a big max file (20Km on 20 Km) that I want to cut into separated smaller pieces (5Km on 5Km)
I thought I could use the ProBoolean tool in a script but it doesn’t work at all
I have a few objects and I created a bounding box for that area
This is the full script:
newPos = $.pos delete $ max select all objNum = selection.count theObjs = selection clearSelection() for i = 1 to 1 do ( mybox = box length:5000 width:5000 height:500 mybox.pos = newPos print “Boolean” ProBoolean.createBooleanObjects theObjs[i] mybox 1 1 1 convertTo theObjs[i] Editable_Poly )
If you can help me with the script/give me a different idea that would be great
Thank you
I think you have the createBooleanObjects parameters reversed - the first is operand A, and the second is an array of nodes to use as operand B. So this would work:
ProBoolean.createBooleanObjects mybox theObjs 1 1 1
Hope that helps,
Drew
