3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Missing UVs when exporting GLB file.
3 REPLIES 3
idealight
392 Views, 3 Replies
Have an issue with some geometry export. During a light bake all UVs seams to be ok, but after an export some parts\meshes are dissapear in the UV (2nd channel). I have already tried everything (Reset Xform, Weighted normals, Reset Scale)
I notice that GLB missed somethimes some parts of UVs. But FBX exports UVs properlly.
Please see the pictures
Also note that I do not why but therer is also mismatch in Vertexes quantity 14 221 vs 34 970
What did I miss and what should i try to reset to fix this issue?
Any suggestions?
Thank you!
Labels (3)
3 REPLIES 3
how do you control the uv set and vertex count after export? how do you import GLB file back?
what MAX version do you use?
@denisT.MaxDoctor
Thanks for your answer 2024 Max - and Blender
About differences in vertices its the problem that exporting or importing GLB breaks the geometry not by element how it was but randomly by poligons sometimes.
I import GLB to Blender. No possibility to check it on MAX
@idealight wrote:
@denisT.MaxDoctor
that's why I ask...
why do you think MAX is doing something wrong and not Blender?
by the way... you can try to export JSON (text, not a binary) version. At least you will be able to control why Blender can't import it.
