the solution is very simple and straightforward ... if you cast a ray from this point in any direction and:
#1 ray doesn't intersect mesh faces - OUTSIDE
#2 ray intersects but the first hit face's normal is opposite to ray direction - OUTSIDE
#3 ray intersects and the first hit face's normal has the same direction of the ray - INSIDE
@denisT.MaxDoctor wrote:the solution is very simple and straightforward ... if you cast a ray from this point in any direction and:
if the mesh is closed but not convex there is another rule...
(still cast a ray from the point to any direction):
#1 no hit - OUSIDE
#2 even number of hits - OUTSIDE
#3 odd number of hits - INSIDE
You can use the code in post 6 in this thread: https://forums.cgsociety.org/t/find-verts-inside-other-mesh/1456824/6
and following denisT advices you can build your tool.
@miauuuu wrote:You can use the code in post 6 in this thread
today is 2021 ... let's do something smarter:
fn isPointInsideGeometry node pt =
rm = RayMeshGridIntersect()
rm.Initialize 10
rm.addnode node
rm.buildGrid()
numhits = rm.intersectRay pt z_axis on
hitpoints = #()
for index = 1 to numhits do appendifunique hitpoints (rm.getHitPoint index)
res = mod hitpoints.count 2 == 1
rm.free()
res
fn arePointsInsideGeometry node pts =
rm.Initialize 10
rm.addnode node
rm.buildGrid()
res = for pt in pts collect
hitpoints = #()
rm.free()
res
@denisT.MaxDoctor wrote:if the mesh is closed but not convex there is another rule...
#1 no hit - OUSIDE
As you wrote about "not convex". Concave objects won't work with a test ray in any direction..
@istan wrote:As you wrote about "not convex". Concave objects won't work with a test ray in any direction..
why not? the odd / even solution works for any "closed" mesh (both convex and concave). it must be not a self-intersecting mesh, a single-element or its elements must not overlap.
rm.Initialize 10
rm.addnode node
rm.buildGrid()
hitpoints = #()
rm.free()
res
delete objects
gc()
t = torus_Knot radius:20 radius2:6 wirecolor:green
pp = for k=1 to 1000 collect
point pos:(random t.min t.max) size:5 wirecolor:brown
pts = for p in pp collect p.pos
cc = arePointsInsideGeometry t pts
for k=1 to pp.count do pp[k].wirecolor = if cc[k] then red else gray
Thank you all guys! I solved my problem by following the example:
3ds Max 2016 Help: RayMeshGridIntersect : ReferenceTarget (autodesk.com)
I needed it for a very basic application and that works well.
@denisT.MaxDoctor I'll look at your script too, maybe I can optimize what I wrote. Thanks 🙂
@Anonymous wrote:Thank you all guys! I solved my problem by following the example...
in that case, please show your solution
thanks for sharing, found this quite useful - just a short note that your code seems not to work for a teapot.
Martin Breidt
http://scripts.breidt.net
@MartinBeh wrote:thanks for sharing, found this quite useful - just a short note that your code seems not to work for a teapot.
A teapot geometry is not a "closed" mesh. As I remember the solution works for a "closed" mesh only. You can "cap" the teapot and try the solution again.
I did try adding a Cap modifier but still getting some points outside the teapot reported as "inside", e.g. below the spout.
Have not tried to debug it yet, just wanted to let you know.
Teapot is special anyway...
Martin Breidt
http://scripts.breidt.nettry to increase the ray-to-mesh intersection grid size to 1000 and number segments for the teapot. It has to work with the example below:
rm.Initialize 1000
rm.addnode node
rm.buildGrid()
hitpoints = #()
hitpoints.count > 0 and (mod hitpoints.count 2 == 1)
rm.free()
res
delete objects
gc()
t = teapot radius:20 segs:100 wirecolor:green
addmodifier t (cap_holes())
point pos:(random t.min t.max) size:2 wirecolor:gray
xp = for k=1 to pp.count collect
if cc[k] then
pp[k].wirecolor = red
dontCollect
else pp[k]
-- select xp
The algorithmic logic is correct, but the built-in RayMeshGridIntersect methods are probably buggy (not working correctly) for some values.
Makes sense! If RayMeshGridIntersect does not work precisely, the rest cannot do a good job, either.
Unfortunately, adding a Cap_Holes modifier and increasing the grid size to 1000 still generates a few false positives. In fact, there is no difference between 10 and 1000 (aside from calculation times...).
FWIW: I am testing with code that generates the test points in a regular grid within the bounding box, not random points.
Martin Breidt
http://scripts.breidt.netWe can do it faster with a smaller grid but test all three directions. (or more than three, the rule is the same - odd number of intersections)
fn _odd x = (mod x 2 > 0)
rm.Initialize 100
rm.addnode node
rm.buildGrid()
x = rm.intersectRay pt x_axis on
y = rm.intersectRay pt y_axis on
z = rm.intersectRay pt z_axis on
_odd z and _odd y and _odd z
rm.free()
res
delete objects
gc()
seed 100
t = teapot radius:20 segs:10 wirecolor:green
if cc[k] then
dontCollect
else pp[k]
Martin Breidt
http://scripts.breidt.netThe main issue in your case appears to be algorithmic.
The "method of parity of intersections" only works for a single closed figure, regardless of whether it is convex or not.
In the classic case of the teapot, we are dealing with several elements, and they are not closed. If we apply the Cap modifier, we can close the shapes (elements), but since there are still multiple elements, this contradicts the algorithm's conditions. Therefore, to determine a point's position relative to the entire teapot (inside or outside) we must check for mutual intersections among all elements.
One possible solution could be to use a Boolean (Union) operation on all elements. However, this may be a computationally heavy operation in general.
