Announcements
Change the bitmap properties using maxcript
osukas
osukas
Im importing a texture from Plantfactory, and im getting all this ON, the texture looks good in my viewport but not in the render, if I manually deactivate the two checks in TILE works great. I noticed that trying to activate all these 4 manually is impossible, if you activae mirror deactivates Tile, and the same way if i do it backwards. So im trying to make a max script to automate that if MIRROR is active, deactivates the TILE, but i cant get the "name" to edit that data
https://help.autodesk.com/view/MAXDEV/2024/ENU/?guid=GUID-F31D331A-D62B-4E31-8579-24911D35CD3D
when googling the name of the properties, I get the name of the properties of a general bitmap (clipU, clipV, filtering, filename) but nothing about the properties in coordinates, that is what i need to start making the script.
Where i can find this data?
I google trying to find how to modify "offsetU" or "angleU" but nothing
osukas
FIXED, I used ZORB tools to get the names of what I was looking for
https://www.scriptspot.com/3ds-max/scripts/modifier-modifier-zorb
worked it with chat gpt to get a working script to fix my issue, sharing it here in case is useful for someone
for b in getClassInstances bitmaptex do
    local coords = b.coords
    if coords != undefined do
        if coords.U_Mirror == true and coords.U_Tile == true then
            coords.U_Mirror = true
            coords.U_Tile = false
            print ("Updated: " + b.name + " U_Mirror: true, U_Tile: false")
        if coords.V_Mirror == true and coords.V_Tile == true then
            coords.V_Mirror = true
            coords.V_Tile = false
            print ("Updated: " + b.name + " V_Mirror: true, V_Tile: false")
MartinBeh
You can ask MAXScript itself for the names/properties:
m = Bitmaptexture()
Bitmaptexture:Bitmap
show m
  .clipu (Clip_U_Offset) : float
  .clipv (Clip_V_Offset) : float
  .clipw (Clip_U_Width) : float
  .cliph (Clip_V_Width) : float
  .jitter (Jitter_Placement) : float
  .useJitter : boolean
  .apply : boolean
  .cropPlace : integer
  .filtering : integer
  .monoOutput : integer
  .rgbOutput : integer
  .alphaSource : integer
  .preMultAlpha : boolean
  .bitmap : bitmap
  .coords (Coordinates) : maxObject
  .output : maxObject
  .fileName : filename
  .startTime : time
  .playBackRate : float
  .endCondition : integer
  .tieTimeToMatIDs : boolean
and
show m.coords
  .blur : float
  .mapping
  .mapChannel : integer
  .mappingType : integer
  .UVW_Type : integer
  .U_Mirror : boolean
  .V_Mirror : boolean
  .U_Tile : boolean
  .V_Tile : boolean
  .showMapOnBack : boolean
  .Noise_On : boolean
  .Noise_Animate : boolean
  .UVTransform
  .realWorldScale : boolean
  .realWorldHeight : float
  .realWorldWidth : float
  .phase : float
  .U_Offset : float
  .V_Offset : float
  .U_Tiling : float
  .V_Tiling : float
  .U_Angle : angle
  .V_Angle : angle
  .W_Angle : angle
  .Noise_Amount : float
  .Noise_Size : float
  .Noise_Levels : integer
  .Blur_Offset : float
So for your case, you would use m.coords.U_Tile = false, for example.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
