I want to call Python from MaxScript and get the value obtained in Python.
If I execute the following code, I can call Python from MaxScript.
python.Execute "print('test')"
However, I will not be able to get the return value.
I tried the following code, but it did not work.
test = python.Execute "'one,two,three,four,five'.split(',')"
print(test[1])
Is there a way to get the return value in Python?
Solved by Swordslayer. Go to Solution.
Use python.import instead and call the python modules from MAXScript:
py = python.import "builtins" /* or "_builtin_" in 2020 and before */
py.str.split "one,two,three,four,five" "," as array
I have one more question.
I have the following Python code.
This is the code to retrieve text data from a web site.
Is it possible to call such complex Python code from MaxScript?
from urllib import request response = request.urlopen('https~~~') content = response.read() response.close() html = content.decode() title = html.split('<title>')[1].split('</title')[0] print(title)
Of course
request = python.import "urllib.request"
response = request.urlopen @"https~~~"
response.close()
html = content.decode() as stringStream
skipToString html "<title>"
title = readDelimitedString html "<"
print title
The following code works in Python3 & max script.
py = python.Import "builtins"
splited = py.str.split "testA_testB" "_" as array
However, the following code will not work in Python2 & max script.
What do I need to do to split in Python2?
py = Python.Import "__builtin__"
In Python2, I get the following error
TypeError: descriptor 'split' requires a 'str' object but received a 'unicode'
-- Error occurred in anonymous codeblock; filename: ; position: 74; line: 2
-- Runtime error: TypeError: descriptor 'split' requires a 'str' object but received a 'unicode'
-- MAXScript callstack:
-- thread data: threadID:1268
-- [stack level: 0]
-- In top-level
@YASUSHI_EMOTO wrote:The following code works in Python3 & max script.
splited = py.unicode.split "testA_testB" "_" as array
Use directly a MAXScript call instead of going through Python.
FilterString "testA_testB" "_"
