3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
How to call Python from MaxScript and get the value obtained in Python
7 REPLIES 7
Message 1 of 8
YASUSHI_EMOTO
1366 Views, 7 Replies
I want to call Python from MaxScript and get the value obtained in Python.
If I execute the following code, I can call Python from MaxScript.
python.Execute "print('test')"
However, I will not be able to get the return value.
I tried the following code, but it did not work.
test = python.Execute "'one,two,three,four,five'.split(',')"
print(test[1])
Is there a way to get the return value in Python?
Labels (4)
7 REPLIES 7
Message 2 of 8
Swordslayer
in reply to: YASUSHI_EMOTO
Use python.import instead and call the python modules from MAXScript:
py = python.import "builtins" /* or "_builtin_" in 2020 and before */
py.str.split "one,two,three,four,five" "," as array
Message 3 of 8
YASUSHI_EMOTO
in reply to: Swordslayer
I have one more question.
I have the following Python code.
This is the code to retrieve text data from a web site.
Is it possible to call such complex Python code from MaxScript?
from urllib import request
response = request.urlopen('https~~~')
content = response.read()
response.close()
html = content.decode()
title = html.split('<title>')[1].split('</title')[0]
print(title)
Message 4 of 8
Swordslayer
Of course
request = python.import "urllib.request"
response = request.urlopen @"https~~~"
response.close()
html = content.decode() as stringStream
skipToString html "<title>"
title = readDelimitedString html "<"
print title
Message 5 of 8
YASUSHI_EMOTO
The following code works in Python3 & max script.
py = python.Import "builtins"
splited = py.str.split "testA_testB" "_" as array
However, the following code will not work in Python2 & max script.
What do I need to do to split in Python2?
py = Python.Import "__builtin__"
In Python2, I get the following error
TypeError: descriptor 'split' requires a 'str' object but received a 'unicode'
-- Error occurred in anonymous codeblock; filename: ; position: 74; line: 2
-- Runtime error: TypeError: descriptor 'split' requires a 'str' object but received a 'unicode'
-- MAXScript callstack:
--	thread data: threadID:1268
--	[stack level: 0]
--	In top-level
Message 6 of 8
splited = py.unicode.split "testA_testB" "_" as array
Message 7 of 8
@YASUSHI_EMOTO ,
Use directly a MAXScript call instead of going through Python.
FilterString "testA_testB" "_"
Eric Brosseau
Senior Software Developer, 3ds Max, Autodesk
Message 8 of 8
Thanks a lot!
