We are currently looking into supporting additional texture nodes for Max standard material such as RGB Multiply, Tint and those nodes.
We are able to identify nodes and textures with Texmap, GetSubTexmap ,BMTEX_CLASS_ID, GNORMAL_CLASS_ID, RGBMULT_CLASS_ID and so on. But how do we get access to the rest of the node properties, such as color and blend modes inside these nodes?
For DX shaders many years ago we had to move over to param block traversal to be able to read and write properties, is this the way to go or are there other API calls to fetch color and bool values from a node?
Language: C++
Max version: Max 2020 and earlier
what is the problem? you should understand that all mxs methods are by MAX SDK, so see:
t = RGB_Multiply()
showproperties t
getpropnames t
for k=1 to t.numsubs collect getsubanimname t k
and, of course, we can always ask the paramblock (s) of the object about the parameters ...
Thanks!
I was just hoping for a simpler method of fetching data. We are not really interested in third party nodes so an interface for each node would've been great. We managed to solve it by traversing param blocks similar to our previous solution for dx shaders, and having the parameter fetching as a templated function minimizes the code so I guess that is fine for now.
Printing the properties using MaxScript seems like a good idea, to be able to see the property names and types beforehand.
