We have a paramblock in which the user can pick objects in the scene to connect them to our own object. (See picture)
With a paramblock2 descriptor snippet:
constraint_list_body1, _T("body1"), TYPE_INODE_TAB, 0, P_VARIABLE_SIZE, IDS_CONSTRAINT_BODY1_LIST,
p_ui, TYPE_NODELISTBOX, IDC_EABASE_LIST1, 0, 0, 0,
p_end,
It works, however the max script programmers now need to index the parameter if they use it from script.
For example:
object.body1[1] = picked_object
instead of:
object.body1 = picked_object
Can anyone help me with this? I haven't found the correct paramblock2desc syntax to make this work.
Thanks in advance!
@bdenhartog wrote:We have a paramblock in which the user can pick objects in the scene to connect them to our own object. (See picture)
p_end,
For example:
instead of:
Thanks in advance!
Did you search for "TYPE_INODE_TAB" in the samples? What does "showproperties $" show?
Your 'body1' variable should display as type 'node array'.
And with MXS use 'append' to add new nodes to the list.
