Access selected node in Slate Material editor
Hi everyone,
Using maxscript, I would like to access / modify properties of the selected node in the slate material editor.
I would do simple things like changing the name of the selected bitmap or selected material.
I didn't find anything in maxscript help.
I don't know if slate material editor is accessible via maxscript or if autodesk blocked it for the moment.
Can somebody help me ?
You should check out the SME Interface.
Documentation for 3dsMax 2018
michaelsonbritt
Try this:
((sme.getview 1).GetSelectedNodes())[1].reference
To see how this was determined, see the attached is a screenshot.  It shows a script log, with the steps used and some comments on the left.  Just took a couple minutes to find the exposure by poking around.
Cheers,
Michaelson Britt
Thanks a lot michaelsonbritt !
That's exacly what I needed !
Thanks alexcgt !
Seems like I didn't search too well in autodesk documentation.
Sorry about that.
Thanks !
dmitriy.shpilevoy
That was some MAX CSI detective work, thank you for posting the process.
