3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Access selected node in Slate Material editor
5 REPLIES 5
2945 Views, 5 Replies
Hi everyone,
Using maxscript, I would like to access / modify properties of the selected node in the slate material editor.
I would do simple things like changing the name of the selected bitmap or selected material.
I didn't find anything in maxscript help.
I don't know if slate material editor is accessible via maxscript or if autodesk blocked it for the moment.
Can somebody help me ?
5 REPLIES 5
You should check out the SME Interface.
Documentation for 3dsMax 2018
michaelsonbritt
Try this:
((sme.getview 1).GetSelectedNodes())[1].reference
To see how this was determined, see the attached is a screenshot.  It shows a script log, with the steps used and some comments on the left.  Just took a couple minutes to find the exposure by poking around.
Cheers,
Michaelson Britt
in reply to: michaelsonbritt
Thanks a lot michaelsonbritt !
That's exacly what I needed !
Thanks alexcgt !
Seems like I didn't search too well in autodesk documentation.
Sorry about that.
Thanks !
That was some MAX CSI detective work, thank you for posting the process.
