3dmax 2017 problem in physical camera in vray 3.4
same7_snake
Message 1 of 16
same7_snake
i can't find a physical camera in vray 3.4 in 3dmax and i want to download it so please send me a link to i can download it
Replies (15)
Message 2 of 16
Swordslayer
From 2016 on, max uses new Physical camera based on code from Vlado (Vray dev), it's in the Standard category, not Vray:
If you want the traditional VRay Physical camera instead (basically deprecated and not available from the UI), enter vrayCreateVRayPhysicalCamera() in the MAXScript Listener and press Enter, it will create one.
Message 3 of 16
same7_snake
it says "undefined"
Message 4 of 16
Swordslayer
What vray version? Works in vray 3.40.01 @ max 2017:
What's the reason you want to use that one instead of the Physical cam? It was made based on vray camera source code anyway.
Message 5 of 16
same7_snake
Untitled.pngit's not working and i don't know what is going on !!!!!
Message 6 of 16
Swordslayer
So you're on a newer version 3.40.02 or 3.40.03, right? The old Vray Physical Camera is there only for backwards compatibility when opening old scenes that use it, it's not creatable and this was a workaround method, most probably dropped now. As I said, you should use the max Physical camera instead.
Message 7 of 16
same7_snake
thanks a lot but i want to ask about something it will be the same when i render in vray or not ???
and aging thanks for helping me
Message 8 of 16
Swordslayer
Yes, it's now renderer agnostic (it's a part of the continuing effort to make max easier to use with 3rd party renderers) and matches the original VRayPhysicalCamera functionality. Note that when you create a Physical camera, a new Exposure Control is created and active (press 8 to bring up the Environment and Effects dialog, it's under Exposure Control) which effectively overrides the exposure settings of the camera itself - just something to be aware of.
Message 9 of 16
U have typed wrong code in MaxScript  ...its working
Message 10 of 16
i had that problem in max 2017 with vray 3.5 but it's solved now by coding vray physical camera
Thank you ....
Message 11 of 16
i tried the command on maxscript listener but it didn't work rather my renderings are being blanked out with white(being too bright in white)
Message 12 of 16
mauryarte
Message 13 of 16
THANKS !!!
Message 14 of 16
Can I know where to find it after installed successful?
Message 15 of 16
Tnx for help!!! It works
Message 16 of 16
hi, it was so useful the solution. Thanks. i have a question through this though, i have a problem with the lights now, i mean i set them but in render they doesn't have any effect. so i was wondering if the problem is that i'm using physical camera, and Vray ilghts. could it be ? because i'm doing exterior renders and i have Vraysun, Vray light Dome, but they don't have effect.
