What is the root directory for relative path?
If I use the relative path rather than the absolute path in the scripts in 3dmax, what is the default path?
There is an example below, where should i put this file?
drew_avis
It looks like by default it will read/write to the current directory, which is the current running script's path (unless the script does something to change that).  You can get the max root with getdir #maxroot.  See this topic for getting various system paths.
Hope that helps,
Drew
Drew Avis
Content Experience Designer
