What is the difference between 'assignment' and 'equality' operators
dvgbaokar
dvgbaokar
HI
Learning max script with help of "Script help documentation"
In FAQ s came across this question
"What is the difference between 'assignment' and 'equality' operators'
While evaluating in listener and editor both codes give same result
not throwing any error in the first case when " if a = 0 " is written instead of " a ==0"
TYPICAL ERROR:
   a = 1
   if a = 0 then print "A is Zero!" else print "A is not Zero!"
   -- Type error: if-test requires BooleanClass, got: 0
CORRET CODE:
   a = 1
   if a == 0 then print "A is Zero!" else print "A is not Zero!"
   -->"A is not Zero!"
MartinBeh
1.) a = 0 is an assignment in MAXScript, i.e. "store the value 0 in the variable a"
2.) a == 0 is an equality comparison, i.e. "check whether a contains the value zero"
But you are right!
MAXScript no longer complains about
     if a=0 then ( ... )
You can also simply write
     0==false
and get "true" as result, without an error
Not sure when this was changed! It used to throw an error, but now it seems to do the same many other programming languages do:
It will use "0" as equivalent to "false"...
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
istan
Fortunately you must not write now (a === b) 😁
