Announcements
View Spline Knots Coordinate Values
Message 1 of 10
So I have a Spline3D with knots on it. The values of these knot points are then extracted using GetKnot(i).Knot() which returns the point location (in Point3 form) for the i-th knot.
Now when I load this spline on 3ds max and I choose "select and move" on a knot point/vertex, I can see values on the Coordinate Display:
However, the extracted point location using GetKnot(i).Knot() is different from the values showing in the Coordinate Display, regardless of what Reference Coordinate System I choose (local, view, screen, etc).
e.g. first extracted point location using GetKnot(i).Knot() is [-297.29, 223.29, 925] but the values in the Coordinate Display differ (pictured above).
My questions are:
1. Is it actually possible to view the extracted point location (one obtained using GetKnot(i).Knot()) inside 3ds max UI?
2. If yes, am I checking the correct display window (Coordinate Display)? Or is there a different window/panel for this? If there is, I am hoping you would guide me to the right window/panel.
3. If it should be viewable in the Coordinate Display, am I missing some settings/configuration which is causing the mismatch on the values that I am seeing?
4. Lastly, if ever I find the way to view this extracted point location, are the coordinate values modifiable inside 3ds max UI? <- Actually this is my final need: to manually modify the extracted point locations by editing the coordinate values in 3ds Max UI.
Any info or tip would be of great help. Thanks!
Replies (9)
Message 2 of 10
istan
C++ ?
Message 3 of 10
yes c++. sorry about that I forgot to mention it.
Message 4 of 10
denisT.MaxDoctor
You must get the Knot point and translate it using the transform of the node's object transform ((Point3 * Matrix3) or Matrix3::PointTransform(Point3)).
Spline3D knot value is in local space.You need the world position, which is displayed in the MAX transform type-in controls
Message 5 of 10
istan
Yep. MXS behaves in this detail different..
Message 6 of 10
leeminardi
Check that your system units and display units are the same. Set the coordinate to world to world and then compare your script coordinate values to the world coordinates.
lee.minardi
Message 7 of 10
istan
Wasn't he talking about C++ code?
Message 8 of 10
leeminardi
Yes but he was trying to verify the coordinates he was getting in his program with the coordinates he sees on the screen.  Screen coordinates will not agree with GetKnots coordinates  if the system and display units are not the same.
lee.minardi
Message 9 of 10
domo.spaji
Animate some spline verts and compare values in UI and curve editor.
Message 10 of 10
Hi all,
So I tried the following based on your suggestions:
1. @leeminardi I made sure that unit display and system display are in sync. Before the unit display was in meters but my system unit is in millimeters, so I changed the unit display to millimeters.
2. @denisT.MaxDoctor I performed Matrix3::PointTransform() for the knot points using the GetObjectTM() for the matrix.
I can now see the extracted values from the code in the Coordinate Display! Thanks a lot!
