use expose transform distance var for AddScalar Target
im wanting to make a script that will set up a float expression script for bone stretch.
i have a bone where i add a ScaleXYZ controller with a float expression assigned to Z scale. theres an expose transform tracking the distance of 2 helpers where the bone is in between.  the distance is used to stretch the bone.
$[2].distance is not acceptable for the AddScalerTarget.  how can i have the distance variable of the expose transform be accepted into the function?
$[1] is the bone selection where the script will be placed
$[2] is the expose transform
	on addStretchScript pressed do
		etDistance = $[2].distance as string
		dExpression = "dist/" + etDistance
		$[1].scale.controller = ScaleXYZ ()
		$[1].scale.controller.Z_Scale.controller = Float_Expression ()
		$[1].scale.controller.Z_Scale.controller.AddScalarTarget "dist" $[2].distance
		$[1].scale.controller.Z_Scale.controller.setExpression dExpression
i figured out as follows.
		if selection.count == 2 then
			etDist = $[2]
			$[1].scale.controller.Z_Scale.controller.AddScalarTarget  "dist" etDist[4][17]
etDist[4] = #Object__ExposeTransformHelper
[17] = SubAnim:Distance  (this is what the function requires)
