MXS dotNet exception
istan
Advisor Advisor
istan
Why I'm getting an exception here, when <ESC> is pressed ?
fn foo = (
  local theFrm = dotNetObject "System.Windows.Forms.Form"
  -- doesn't matter - same effect:
  --local theFrm = dotNetObject "MaxCustomControls.MaxForm"
  theFrm.width = 200
  theFrm.height = 100
  theFrm.text = "DotNet Form"
  local Input = dotNetObject "System.Windows.Forms.TextBox"
  Input.location = dotNetObject "System.Drawing.Point" 0 20
  Input.width = 50
  Input.height = 30
  Input.Text = "foo"
  theFrm.controls.add Input
  -- this assignment causes the exception?!
  dotNet.addEventHandler Input "KeyDown" ( fn foo s e = () )
  local txt = dotNetObject "System.Windows.Forms.Label"
  txt.location = dotNetObject "System.Drawing.Point" 0 2
  txt.text = "Press the <ESC> key.."
  txt.width = 200
  theFrm.controls.add txt
  try thefrm.ShowDialog() catch()
foo true
denisT.MaxDoctor
When working with a .net TextBox form control, as a rule, you need to do a few basic things:
# disable / enable accelerators
# decide what to do with Return, Escape and Tab
# deal with the beep sound on these keys
this example shows how to do this:
fn GotFocus s e =
	s.text = ""
	enableAccelerators = off
fn LostFocus s e =
	s.text = "Type here"
	enableAccelerators = on
fn KeyDown s e =
	if ((e.KeyCode == e.KeyCode.Enter) or (e.KeyCode == e.KeyCode.Tab) or (e.KeyCode == e.KeyCode.Escape)) do
		e.Handled = e.SuppressKeyPress = true
fn KeyUp s e =
	case e.KeyCode of
		 (e.KeyCode.Enter): print "enter"
		(e.KeyCode.Escape): print "escape"
form = dotnetobject "maxcustomcontrols.maxform"
form.width = 200
form.height = 100
form.text = "DotNet Form"
tb = dotNetObject "System.Windows.Forms.TextBox"
tb.location = dotNetObject "System.Drawing.Point" 20 20
tb.width = 140
tb.height = 30
tb.AcceptsReturn = on
form.controls.add tb
dotnet.addeventhandler tb "GotFocus" GotFocus
dotnet.addeventhandler tb "LostFocus" LostFocus
dotnet.addeventhandler tb "KeyDown" KeyDown
dotnet.addeventhandler tb "KeyUp" KeyUp
form.showmodeless()
istan
Sorry to say, but your code also spits out an exception, when I press <Escape>.
btw: Max2020 but also happens in 2017..
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Runtime.InteropServices.SEHException (0x80004005): External component has thrown an exception.
   at _CxxThrowException(Void* , _s__ThrowInfo* )
   at MXS_dotNet.DotNetObjectWrapper.ProcessEvent(DotNetObjectWrapper* , String eventName, Object delegateArgs)
   at MXS_dotNet.DotNetObjectManaged.delegate_proxy_type.ProcessEvent(String eventName, Object delegateArgs)
   at System.Windows.Forms.Control.OnKeyDown(KeyEventArgs e)
   at System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
   at System.Windows.Forms.Control.WmKeyChar(Message& m)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.TextBox.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
denisT.MaxDoctor
Oh! My bad. I have not tested this in versions 2016+
I am sure that this is Autodesk's fault. TextBox always worked for me until 2016+. You can also see that ComboBox, for example, works fine, although it uses the same “edit control”.
istan
I'll open a ticket..
denisT.MaxDoctor
Now I am absolutely sure that this is an Autodesk's bug.
The simplest example to see is:
fn KeyPress s e =
form.KeyPreview = on
dotnet.addeventhandler form "KeyPress" KeyPress
form.showmodeless()
This is easy to see if KeyPreview is set to TRUE.
I can solve the problem by overriding ProcessKeyMessage, but this should no doubt be fixed by Autodesk
