UI errors after ENU file delete
FE-S
FE-S
Had to reset the UI via ENU deletion after losing VFB. On startup after that there was an error message about access to a file but it did not seem significant (program functioned normally), now the vray light lister is displaying incorrectly. I know this is not an autodesk issue, but I'm assuming the solution will be found through a native pathway given that this was the case for resetting VFB location.
Thanks for any help
FE-S
No longer occuring
