SDK MaxScript Function Publishing
MehdiZangenehBar
Message 1 of 13
MehdiZangenehBar
I just want to recreate InterpCurve3D in c++ and publish it to the MaxScript. this is the c# version:
using Autodesk.Max;
namespace MyProject
    public static class MyClass
        static IGlobal g = GlobalInterface.Instance;
        static IInterface14 i = g.COREInterface14;
        public static IPoint3 InterpCurve3D(uint handle,float param)
            IINode node = i.GetINodeByHandle(handle);
            IObject obj = node.EvalWorldState(g.COREInterface.Time, true).Obj;
            ISplineShape shape = obj as ISplineShape;
            return shape.InterpCurve3D(0, 0, param, 0);
and this is the c++ version that I'm trying to create:
#include <maxscript/maxscript.h>
#include <maxscript/macros/define_instantiation_functions.h>
#include <maxscript/foundation/numbers.h>
def_visible_primitive(SampleFunction, "SampleFunction");
Value*
SampleFunction_cf(Value** arg_list, int count)
	INode* node = arg_list[0]->to_node;
	float param = arg_list[0]->to_float;
	ReferenceTarget* ref = node->GetObjectRef();
	TimeValue t = GetCOREInterface()->GetTime();
	ObjectState os = node->EvalWorldState(t);
	ShapeObject* spline = (ShapeObject*)os.obj;
	Point3 result = spline->InterpCurve3D(t,1,param,0);
In "IntervalArray" example, I saw return_value_tls for returning value, but actually I don't know how I can use it. I'm using VS 2017, Max 2018
Accepted solutions (4)
Replies (12)
Message 2 of 13
istan
return new Point3Value(result );
pretty simple..
Message 3 of 13
MehdiZangenehBar
Not working...
Point3Value >> expected a type specifier
Message 4 of 13
istan
3dmath.h included?
Message 5 of 13
MehdiZangenehBar
Now works, Thank You. but I still got errors on build. this is my code:
#include <maxscript/foundation/3dmath.h>
Value*
	return new Point3Value(result);
Errors:
qualified name is not allowed in member declaration
Message 6 of 13
denisT.MaxDoctor
	INode* node = arg_list[0]->to_node();
	float param = arg_list[1]->to_float();
Message 7 of 13
MehdiZangenehBar
Finally I build the code :), Thank You!
Message 8 of 13
MehdiZangenehBar
I'm new to c++ and I have some beginner questions:
Why I should use Point3Value instead of Point3?
Why IntervalArray used return_value_tls instead of return?
Message 9 of 13
denisT.MaxDoctor
#1 every published function has to return MXS Value... Point3Value is a wrapper for c++ SDK Point3
#2 return_value_tls is special macros to return mxs value and free allocated for local values memory. in your case you don't have to do it
Message 10 of 13
istan
As you wrote you are a C++ beginner: Honestly, just a tip: I would not start learning C++ by writing plugins for 3dsmax.
Message 11 of 13
MehdiZangenehBar
You right, I should learn basic of C++ first, But actually at the moment I don't want to work on large projects, I just want to expose some necessary functions to MaxScript. So this challenges will encourage me to learn C++ and helps me to understand what I should learn first.
Message 12 of 13
MehdiZangenehBar
When I move the line
Before
My function in MaxScript will be undefined. So my question is include priority matters?
Message 13 of 13
MehdiZangenehBar
I'm so exited! it works very well so far:
def_visible_primitive(ShapeInterp, "ShapeInterp");
Value* ShapeInterp_cf(Value **arg_list, int count)
	int curveIndex = arg_list[1]->to_int();
	float percent = arg_list[2]->to_float();
	int type = arg_list[3]->to_int();
	ShapeObject* shape = (ShapeObject*)node->EvalWorldState(t).obj;
	Point3 result = shape->InterpCurve3D(t, curveIndex-1, percent/(float)100,type)*node->GetObjectTM(t);
Compare to the Max version, has great benefits:
  1. Works on any shape not only splines.
  2. Works at WorldState (Max version only works on base object not modifiers).
  3. It's not completed yet, but so far works faster(1.6 times) than default version.
Next I want to add argument cheking and default values.
