-U switch not working in cmd line
I have a .bat file that will work opening any .max file in the same folder.
for /r %%v in (*.max) do start %%v
works great.
I have read the help topic on running MAXScript from CMD line saying:
-U MAXScript rendercams.ms
However I can't get these two working together -  so I can run the .bat file, it open the max file in the same folder and run a certain  script.
Any Ideas why this will not work, and how to get around this please?
Adam
(Also tried -MXS) doesn't work either..
drew_avis
What version of Max?  Can you post a copy of the bat file you are using?
Drew
Drew Avis
Content Experience Designer
Hi mate,
I'm using 2018.
The first bat file attached will do what I need and open any .Max file in the same folder.
The second one I though may do the same be also run any desired script (based in info I found on the Autodesk help).
Ad
Sorry will not post with the bat files attached
drew_avis
Hi, I've had a look at your bat file, and I think I have a working version:
for /r %%v in (*.max) do (
start "" "<path>\3dsmax.exe" -u MAXScript test.ms %%v
The issue was your "start %%v" invokes the default program for %%v (a .max file), but that doesn't pass parameters correctly (in this case -u).
Substitute <path> for your path to 3dsmax.exe.
Hope that helps,
Drew
Drew Avis
Excellent, thanks.
Works great now!
