How to open a max file from c++
Hi everyone,
I have a seemingly very elementary question. I want to open a .max file from my c++ plugin code without an open file dialog.
No matter what I do this code crashes 3ds Max:
ip->LoadFromFile((_T("C:\\thescene.max"), TRUE);
No error message details. Max just crashes whenever I invoke this code. I can open the file manually.
Is there any obvious mistake anyone can see? I am using Max 2014 and everything else is working OK.
If ip is valid then the code should work.
At least it works for me in 3dsMax 2018 when calling from custom MaxScript extensions.
istan
why should ip  be valid? what was assigned to ip  ? could also be a NULL pointer ?!
Oh, we've got a comedian here 🙂
You are right that any pointer is invalid until it is assigned an object to refer to. But *ip is a pointer to the scene interface that the SDK passes to your plugin whenever you start your plugin (BeginEditParams (), if I am not mistaken.) I use the pointer throughout my code for different purposes such as creating and grouping nodes. And it works ok.  The problem is when I use it to open a scene file,  as recommended in the documentation.
