tooltips
tooltips
Message 1 of 11
tooltips
I don't think it's possible but just in case.
Does anyone know how to:
- create a multi line tooltip?
- change how long it is displayed?
Thanks for your time.
Replies (10)
Message 2 of 11
For a new line in a tooltip, I think you can use
\n
Which will insert a carriage return in the tooltip/
Look up escape characters in the maxscript help file.
I don't know about the duration issue though.
Message 3 of 11
Thanks for answering, zzubnik.
\n doesn't work. It is ignored (not displayed in the tooltip) but everything stays on one line.
Message 4 of 11
That is strange, I tried it before I posted and it worked. I have just tried this line with a tool-tip, and it definitely works.
button btn1 "Colorize" pos: width:97 height:18 tooltip: "first line \n second line"
Hope this helps.
EDIT: Not to be outdone, I've also added an image attachment (yes, I am bored) 🐵
Message 5 of 11
Steve_Curley
button btnSelect "&Select" pos: width:49 height:36 Tooltip:("Multi"+"\n"+"Line"+"\n"+"Tooltip")
AFAIK the time a tooltip is displayed is controlled by windows. It may be possible to alter / override that time, but I have a feeling you would need to be working at a much lower level than is exposed by MXS (ie. the SDK) if it is indeed possible to begin with.
zzubnik's method should work too, but if you leave a space after the \ n that space will be displayed
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Message 6 of 11
Strange indeed. It seems to depend on context.
I tried this:
rollout rlt "test" width:100 height:100
button btn1 "button" pos: width:50 height:20 tooltip: "first line \n second line"
createDialog rlt 100 100
and got this:
Edit: I'm using max 9. Could it be that?
Message 7 of 11
Steve_Curley
local test
rollout test "test"
button btnSelect "Select" pos: width:80 height:24 Tooltip:"Multi\nLine\nTooltip"
button btnCreate "Create" pos: width:80 height:24
try (destroyDialog test) catch()
CreateDialog test
Yes - that's your problem, it fails here in Max 9 also. Time to upgrade? 😛
Max 2016 (SP1/EXT1)
Message 8 of 11
I just tried your code. It works fine on 2009, but in max 9 it doesn't display the tooltip correctly.
EDIT: Steve, you type too fast for me!
Message 9 of 11
Ok then. Thanks a lot, guys.
Time to upgrade?
I'd rather wait to see where it's heading.
Message 10 of 11
Steve_Curley
The typing is fast, correcting all the typos takes ages... 😄
Cap - point taken. That should have been in ... tags (TIC = Tongue in cheek) 🙂
Max 2016 (SP1/EXT1)
Message 11 of 11
I know this thread has been dead for almost a year but:
I ran across the need for a multi-line tooltip on an imgTag (to show RGBA values in an orderly fashion). However multi-line tooltip fails here. I tried the imgTag as a button and it works just fine. SO: imgTag cannot have multi-line tooltip (as of max 2010)
