Syntax error: at =, expected name
Im having trouble understanding what the problem is with my code.  the code written below worked without any problems before.  Windows 10 restarted on its own for updates and now my code dosent work.   I get the error below when I try to run my script.  if i remove boneColor = color 86 86 86 the code will run, but when I put this code back  in it stops working and I get the following error. Im using Max 2019.
-- Error occurred in anonymous codeblock; filename: D:\maxScripts\rigTools_3_0.ms; position: 592; line: 9
-- Syntax error: at =, expected name
-- In line: boneColor = c
rollout boneTools "Bone Tools" width:162 height:300
	button 'setUpMuscleBone' "Set Up Muscle Bone" pos:[10,10] width:80 height:40 align:#left
	button 'setUpMuscle' "Set Up Muscle" pos:[10,60] width:80 height:40 align:#left
	edittext baseName "Base Name" pos:[100,10] text:"boneSkin" fieldWidth:75 labelOnTop:true
	edittext side "Side" pos:[100,60] text:"empty" fieldWidth:75 labelOnTop:true
	edittext boneName "Bone Name" pos:[100,110] text:"empty" fieldWidth:75 labelOnTop:true
	checkbox 'muscle' "Is Muscle" pos:[190,10] checked:false width:118 height:42 align:#left
	on muscle changed state do
		if muscle.checked == true then
			baseName.text = "muscle"
			boneColor = color 255 165 0
		else
			baseName.text = "boneSkin"
I
Swordslayer
Part of rollout definitions can only be explicit local declarations, not something that could be assigment expression if the variable was defined in a higher scope. So if you want to have a local variable in that rolout scope, put 'local' in front of it, if you want to override a global, do that in the on rollout open handler.
Thank you.  The code is working now.
mondinodanielfernando
Community Visitor
Community Visitor
Hola tengo este problema con el RUN SCRIPT en 3dmax 2020.
-- Error occurred in anonymous codeblock; filename: D:\DISCO (D)\CLIENTES\Hay alguien abajo VFX\Plano dos Cara trackeada_250.ms; position: 680; line: 14
-- MAXScript FileIn Exception:
-- Syntax error: at ), expected <factor>
-- In line: filename =
HEELP!!!
miauuuu
If you have an error with the script in the above comments use this:
	local boneColor = color 86 86 86
		else
createDialog boneTools
https://miauu-maxscript.com/
