Announcements
If sel = isGroupMember then... Else failing
Hi all,
So close to finishing my script now but I have this odd issues happening, I can array a single mesh on selection (x,y,z values determined by spinners) and I can now array a group on selection thanks to @miauuuu but for some reason if I drop my single selection array as the else of an if statement, it fails to know what I am selecting... can anyone help me out here?
It's the 'Else' that always fails here... example message "No "Select" function for false"
on PickFillMesh picked sel do
		---------- Set Group Selection
		local SelectedGroupHead = (FindGroupHead sel)
		if sel = isGroupMember sel then
		---------- Get Selected Group Dimensions
		SelectedGroupHead.pivot = SelectedGroupHead.center
		SelectedGroupHead.pivot.z = SelectedGroupHead.min.z
		FillGroupWidth = (SelectedGroupHead.max - SelectedGroupHead.min).x
		FillGroupLength = (SelectedGroupHead.max - SelectedGroupHead.min).y
		FillGroupHeight = (SelectedGroupHead.max - SelectedGroupHead.min).z
		if MoveToPallet.state == true then
		SelectedGroupHead.pos =  [0-PalletWidth/2-(0-FillGroupWidth/2),0-PalletLength/2-(0-FillGroupLength/2),149]
			---------- Clone Selected Group and Position
			for HeightAmount = 1 to StackHeight.value do
				for LenghtAmount = 1 to StackLength.value do
					for WidthAmount = 1 to StackWidth.value do
						pos_z = ((HeightAmount-1) * FillGroupHeight)
						pos_y = ((LenghtAmount-1) * FillGroupLength)
						pos_x = ((WidthAmount-1) * FillGroupWidth)
						maxOps.cloneNodes SelectedGroupHead cloneType:#instance offset:[pos_x, pos_y, pos_z]
				--delete original group
				delete SelectedGroupHead
		else
			---------- Set Selection
		Select sel
		---------- Get Selected Mesh Dimensions
		FillMeshWidth = (sel.max - sel.min).x
		FillMeshLength = (sel.max - sel.min).y
		FillMeshHeight = (sel.max - sel.min).z
		---------- Clone Selected Mesh
						pos_z = ((HeightAmount-1) * FillMeshHeight)
						pos_y = ((LenghtAmount-1) * FillMeshLength)
						pos_x = ((WidthAmount-1) * FillMeshWidth)
						FillMesh = copy sel pos:[pos_x, pos_y, pos_z]
Swordslayer
It's exactly what's in the title of your post that's the problem, sel = isGroupMember sel assigns true/false to the sel variable, you wanted just if isGroupMember sel then...
What was it Homer Simpson used to say...
Doh!
Thanks Swordslayer, thats the jobby 😉
