subdivision manager - open beta
Hello everyone,
first i want to apologize for my English on behalf of google translate!
As I have often problems with lack of RAM, I wrote this script to optimize subdivision iterations for editable poly objects. This is the first beta of the script and I want to see if there is interest.
Script analyze the scene and earning statistics for all editabple poly objects that have included nurms subdivision, the number of iterations, the number of polygons and their percent ratio in the scene. Allows for quick change of iterations, switch on and off nurms subdivision.
For the next beta, I plan to add support for meshmooth and turbosmooth
this is a scheme with explanations:
scheme:http://gch-scripts.hit.bg/SD_manager%20scheme_en.jpg
script:http://gch-scripts.hit.bg/subdivide%20manager.ms
script goes in the category "Georgy Chakarov"
c & c about interface, functionality, code and all are welcome
I'm getting errors on the links, maybe use "attach" function?... just don't preview it before you post, this forum loses the attachments if you do.
Hi Georgy,
forget www.hit.bg host,
it has limited access to Bulgarian IP's only,
just suggestion ; )
hit.bg obviously has problems in different parts of the world, some countries have access, other - none. These are the new links:
scheme: http://georgychakarov.eu5.org/scripts/SD_manager%20scheme_en.jpg
script: http://georgychakarov.eu5.org/scripts/subdivide%20manager.ms
