Announcements
simpleMod - Accessing data other than vertex position
I was working on a SimpleMod plugin to have normal based noise, and have a question regarding access to vertex normals within the map event. Currently when trying to run the getNormal command, I get an error saying "-- Runtime error: Illegal SimpleMod map handler recursion: <internal:0x000079c0> ". Is there a way to access not only the local vertex position within the map event but also the vertex normal? And is it possible to have these values update with changing topology beneath the modifier like the P variable does?
plugin simpleMod normalNoise
classID:#(0x3137b97, 0x2c7557ef)
version:1
     parameters main rollout:params
       refNode type:#maxObject
       noiseMult type:#float ui:noiseMultUI
     rollout params "Noise Parameters"
      noiseMultUI "Noise Mult : "
     on create do
       refObj = nodeTransformMonitor node:$ forwardTransformChangeMsgs:false
     on map i p do
       vertNormal = getNormal refObj.node i
       p += (vertNormal * noiseMult)
       p
Swordslayer
Wow I have 2016 but only the 2015 maxscript help. Thanks for introducing me to this plugin class, I didn't even know it existed and am a bit hesitant to jump into the MCG world so this is perfect. Cheers!
