- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was working on a SimpleMod plugin to have normal based noise, and have a question regarding access to vertex normals within the map event. Currently when trying to run the getNormal command, I get an error saying "-- Runtime error: Illegal SimpleMod map handler recursion: <internal:0x000079c0> ". Is there a way to access not only the local vertex position within the map event but also the vertex normal? And is it possible to have these values update with changing topology beneath the modifier like the P variable does?
plugin simpleMod normalNoise
classID:#(0x3137b97, 0x2c7557ef)
version:1
parameters main rollout:params
refNode type:#maxObject
noiseMult type:#float ui:noiseMultUI
rollout params "Noise Parameters"
noiseMultUI "Noise Mult : "
on create do
refObj = nodeTransformMonitor node:$ forwardTransformChangeMsgs:false
on map i p do
vertNormal = getNormal refObj.node i
p += (vertNormal * noiseMult)
p
