Show existing QDockWidget instead of initializing new one
chrisdawlud
chrisdawlud
I have a simple problem with QtDockWidget in PySide2. Whenever I execute my script it creates the UI widget but every new script call creates one more instance of the same UI object instead of showing the already existing one. It's the same situation with demoPySideToolBarQWidget.py example. How do I check and call the UI object which appears under customize ui rollout?hdrimanager_problem.jpg
elpie89
Did you ever found a solution for this?
I have the exact same problem
drew_avis
You could check to see if the Max main window already holds an instance of your widget, and only create a new instance if it doesn't.  Here's an example of this approach:
from PySide2 import QtCore
from PySide2 import QtGui
from PySide2 import QtWidgets
import pymxs
import MaxPlus
def make_cylinder():
    cyl = pymxs.runtime.Cylinder(radius=10, height=30)
    pymxs.runtime.redrawViews()
    return
class PyMaxDockWidget(QtWidgets.QDockWidget):
    def __init__(self, parent=None):
        super(PyMaxDockWidget, self).__init__(parent)
        self.setWindowFlags(QtCore.Qt.Tool)
        self.setWindowTitle('Pyside Qt  Dock Window')
        self.initUI()
        self.setAttribute(QtCore.Qt.WA_DeleteOnClose)
    def initUI(self):
        main_layout = QtWidgets.QVBoxLayout()
        label = QtWidgets.QLabel("Click button to create a cylinder in the scene")
        main_layout.addWidget(label)
        cylinder_btn = QtWidgets.QPushButton("Cylinder")
        cylinder_btn.clicked.connect(make_cylinder)
        main_layout.addWidget(cylinder_btn)
        widget = QtWidgets.QWidget()
        widget.setLayout(main_layout)
        self.setWidget(widget)
        self.resize(250, 100)
def main():
    pymxs.runtime.resetMaxFile(pymxs.runtime.name('noPrompt'))
    mainWindow = MaxPlus.GetQMaxMainWindow()
# check if there's already an instance running dockWidgets = [x for x in mainWindow.children() if x.__class__.__name__ == 'PyMaxDockWidget'] w = None if (len (dockWidgets)>0): w = dockWidgets[0] else: w = PyMaxDockWidget(parent=mainWindow) # Do this if you want to dock the widget initially: # mainWindow.addDockWidget(QtCore.Qt.LeftDockWidgetArea, w) w.setFloating(True) w.show() if __name__ == '__main__': main()
Drew Avis
Content Experience Designer
elpie89
thanks
this worked, as I'm working on a larger tool, I need to attach and remove widget dynamically but, I think I found a bug
Can you take a look at this as well?
