Setting Vertex Color Alpha By UV.Y Position
wyomingstateflag
wyomingstateflag
Hi, I have a pseudo-code version of the function I'm trying to write but I can't quite figure out how to get both the UV and vertex colour from the same vertex. Can anyone help me out with this?
fn UVtoVertColour obj mapChannel = (
    for i = 1 to (polyop.getNumMapVerts obj 0) do
        vCol = polyop.getMapVert obj 0 i
        uv = polyop.getUV obj mapChannel i --NOT A REAL FUNCTION
        vColAlpha = uv.y
        if vColAlpha < 0 then vColAlpha = 0
        if vColAlpha > 1 then vColAlpha = 1
        polyop.setVertColor obj -2 #{i} (color vColAlpha 0 0) --https://forums.autodesk.com/t5/3ds-max-programming-forum/get-amp-set-vertex-alpha/td-p/4020406
MartinBeh
This page might help, especially the section "Finding the corresponding vertices".
Generally: UVs, vertex colors and other channels are linked to the 3D mesh through their faces only, so you will need to do a bit of index shuffling in order to get UV/VC given a mesh vertex number.
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
dmitriy.shpilevoy
Vertex color IS UV.
UV channel 0 is used to store vertex color.
wyomingstateflag
Thanks for the info am I understanding correctly that UV channel -2 is the Alpha of the vertex color? This is honestly very confusing, it feel's like a spiderweb weaving in and out every which way and back onto itself
dmitriy.shpilevoy
Yep, -2 is alpha.
Also keep an eye for gamma correction if you work with vertex color as with color instead of manipulating UVs directly. It gave me a lot of headache.
wyomingstateflag
Thanks for the info shared in this thread 🙂
For anyone reading this in future, this was my solution which was mostly taken and adapted from this thread: https://forums.autodesk.com/t5/3ds-max-programming-forum/error-effect-from-uv-to-vertexcolor/td-p/11...
fn UVtoVertColourAlpha obj mapchannel = (
    polyop.setMapSupport obj -2 true
    visited = #{}
    visited.count = obj.numVerts
    for f = 1 to obj.numFaces do (
        uvVertsFace = polyop.getMapFace obj mapchannel f
        colVertsFace = polyop.getMapFace obj -2 f
        --Loop through all vertices in this face
        for v = 1 to colVertsFace.count where not visited[colVertsFace[v]] do (
            uv = polyop.getMapVert obj mapchannel uvVertsFace[v] --Get UV coord of our vert
            vColAlpha = uv.y
            --Clamp value between 0 - 1
            polyop.setMapVert obj -2 colVertsFace[v] (color vColAlpha vColAlpha vColAlpha)
            visited[colVertsFace[v]] = true
wyomingstateflag
To add to this, I've now put together a full rollout menu where you can selectively edit any of the RGBA channels, select UV channel, UV reference axis. Should be pretty useful for my use case so if anyone might find it useful here it is:
https://github.com/sam563/MaxScripts/blob/main/UVtoVertexColour.mcr
