Announcements
set multiple objects rotation values to 0
grue1970
grue1970
hello.  how can i use maxscript to set the current rotation values of multiple objects to be equal to zero?  i'm not having a lot of luck searching for this.  i did find a script that seems to do the trick, however that script also moves the object quite a distance from where it originally is.  for example some objects i've selected in the viewport are moved a couple hundred feet in the + z world axis, some moved in all 3 world axis several hundred feet.
$.rotation = eulerangles 0 0 0
i'm hoping to find a solution where i can just type it in, vs. a maxscript that has a UI and several options.
thanks!
3ds Max all versions past and present | GPU Rendering on 2 machines | Standard, MentalRay, MentalRay IRAY, IRAY+, VRAY, Arnold
denisT.MaxDoctor
for node in selection do node.transform = translate(scalematrix node.scale) node.pos
denisT.MaxDoctor
or
for node in selection do node.rotation.controller.value = quat 1
denisT.MaxDoctor
both solutions above don't really work if a rotation has keys (animation). animated rotation should be completely replaced.
for exampe:
for node in selection do node.rotation.controller = createinstance euler_xyz
grue1970
thanks a ton this worked great!  i had about 200 2d people that were rotated at different angles on at least 2 axis because of a look-at contraint (to a camera).  i wanted to get them all rotated back to "zero" so i can reapply helpers and look-at's.
definitely going to read about this in the manual.
mateusz.omanskI
I know it has been a while since the topic have been closed but I wonder if it is possible to do this trick but only to one particular axis? I am total lame in maxscript, so if someone have an idea how to do it I would be very greatful 🙂
