Announcements
are there restrictions to what you can type in script controller window?
i want this line to show up in the controller window
information.kerning.controller.SetExpression "SUTheText.text = (bug.distance) as string + "cm" without me having to type it in manually but its not working.
My script over all works fine everywhere but this line
information.kerning.controller.SetExpression "SUTheText.text = (bug.distance) as string\n0" ----this line WORKS when running a script meaning it shows up in the script controller window...so i know \n0 is not the problem
however when I use this script line which adds "cm" it will not show up in the script controller window when i run script
information.kerning.controller.SetExpression "SUTheText.text = (bug.distance) as string + "cm"\n0 ---DOES NOT shows up in the script controller window  when i run script
but it does work if I type in manually in the window.
0"
seems like its the combo of "cm"/n0 that it doesnt like.
Any ideas what could be my problem?
opinions? thank you.
i want this line to show up in the controller window when i run my script
denisT.MaxDoctor
it has to be :
information.kerning.controller.SetExpression "SUTheText.text = (bug.distance) as string + \"cm\""
of course if "SUTheText" and  "bug" are globals or this script controller variable names
thanks...that does work but it doesnt add the 0 on the next line in the window like the /n0     (which means next line put a zero).
how would i add that as well?
oops...putting this seems to work.....+ \"cm\"\n0"
can you elaborate where you got your information and why what you showed me works?
Seems like a totally unpredictable answer
thank you.
denisT.MaxDoctor
because you want to put a string as a parameter of #text property.
i've just made the string complete:
it was:
(a.text = "abc") + "0123"
i made it:
a.text = ("abc" + "0123")
it's just about how to quote an executable string right
what is going on with the back slashes at the end?
+ backslash then quote then cm then backslash then quotes.? Iam lost there.
+ \"cm\""
denisT.MaxDoctor
check for example the MXS Help -> String literals
great! thanks for that direction.
