Announcements
MAX SDK : PB2Value <-> Value (or FPValue)
denisT.MaxDoctor
Advisor Advisor
Message 1 of 9
denisT.MaxDoctor
can anyone point me to built-in methods from/to  Value and PB2Value
thanks
Replies (8)
Message 2 of 9
istan
PBAccessor does this.
Message 3 of 9
denisT.MaxDoctor
Are you sure about PBAccessor?
Message 4 of 9
istan
what exactly you need? I thought you want immediate action on ui input? Or do you simply ask about Set/GetValue()?
Message 5 of 9
klvnk
Don't think theres anything in the core, something like this for PB2Value to Value ....
Value* GetValueFromPB(IParamBlock2* pb, ParamID id, ParamType2 type)
	PB2Value& pb2val =  pb->GetPB2Value(id);
	switch(type)
		case TYPE_INT:
		case TYPE_BOOL:
		case TYPE_TIMEVALUE:
		case TYPE_RADIOBTN_INDEX:
		case TYPE_INDEX:
			return Integer::intern(pb2val.i);
		case TYPE_FLOAT:
		case TYPE_ANGLE:
		case TYPE_PCNT_FRAC:
		case TYPE_WORLD:
		case TYPE_COLOR_CHANNEL:
			return Float::intern(pb2val.f);
		case TYPE_POINT3:
		case TYPE_RGBA:
		case TYPE_HSV:
			return new Point3Value(*pb2val.p);
Message 6 of 9
istan
did you look into \maxsdk\include\maxscript\maxwrapper\mxsobjects.h?
Message 7 of 9
denisT.MaxDoctor
this is exactly what i do... i couldn't find any sdk built-in solution. it doesn't exist
Message 8 of 9
denisT.MaxDoctor
the SDK definitely needs ip's methods PB2Value <->  FPValue
Message 9 of 9
denisT.MaxDoctor
         return int_value(pb2val.i);
         return time_value(pb2val.t);
it seams more correct
