remove ies file
remove ies file
jackietsteh
remove ies file
jackietsteh
Hi i have a lot of vrayies light which i copy as instance and apply same ies file, but when i apply $.ies_file="", it remove all the ies file in the scene, may i know how can i remove just 1 ies file with maxscript?
Jackie
Best regards,
Jackie Teh
Portfolio: http://www.coroflot.com/jackieteh
Youtube Channel:https://www.youtube.com/user/jackieteh
MedalHellWay
I do not think you can do this ... you should only makeunique the VrayLight and delete the IES file.  This however, lose the light property Instance...
jackietsteh
Thank you for reply...may i know how to make unique with maxscript?
Best regards,
Jackie Teh
har1sf0x
 I do not have vray currently installed to test it but the following script should work (it works with Target Spot light):
for obj in selection do obj.baseobject = copy obj.baseobject --select all the lights that you want to make unique before executing this line of script
Enjoy,
har1sf0x
denisT.MaxDoctor
i don't have vray on my machine so i can't test it...
if VRayLight is a class you can:
(getclassinstances VRayLight).ies_file = ""
if *.ies_file is a property only VRayLight light you can:
for light in Lights where isproperty light #ies_file do light.ies_file = ""
