readvalue problem
readvalue problem
readvalue problem
I have a script that exports some Structure values to a file.
When i try to import those values thought the 'readvalue' method, i get the error:
-- Compile error: Undeclared variable: charItems
charItems is the value of the structure.
Now, if i pre-define this structure in the Listener, readvalue will then correctly recognize the charItems structure and import properly without any errors.
What am i doing wrong? My structure is defined in the same script, at the top of the rollout definition...
Swordslayer
ReadValue, just like execute, works in global scope, same way as if you'd be getting/setting things via listener. So for it to work the variable you're accessing in it should either be global or you'd have to use it in a different way (like charItems = readValue ...). Or you can just change it for <rolloutName>.charItems, then it should correctly access the charItems var declared inside rollout scope. Hope it helps.
