Question about loading time for MCR-files
Haider_of_Sweden
Haider_of_Sweden
I'm curious about potential loading time differences between having an MCR containing the full script compared to a small row that loads an MS file (fileIn "filename.ms") when the button or menu item is pressed.
In simpler terms, during loading, is the full MCR evaluated, or just the 'header' (macro name, tooltip, etc.)?
denisT.MaxDoctor
The entire MCR is evaluated upon loading, but it is a quick process and should not cause any issues. However, if you experience a long loading time, it may indicate a specific problem that requires attention.
denisT.MaxDoctor
The usage of filein is a deprecated MXS technique and should not be used in modern mxs coding practices. (IMHO)
Haider_of_Sweden
That answers my question, but I will rename the scripts folder and observe if the startup speed is affected or not.
Just to clarify, are you suggesting that the script inside the .MS file should be placed in an .MCR file instead, and therefore I should not use "filein"? Or did you have any thoughts on "filein" specifically?
denisT.MaxDoctor
On the CGTalk forum (now defunct) I showed in quite a bit of detail how to do "one tool - one file - one global - one structure". In a nutshell, everything is in one MS file in one of the "plugin" folders. This file can contain only one global structure defining the body of the tool(s), user interface, user settings, and launcher of the tool(s) - as a micro-definition.
denisT.MaxDoctor
In another post on the same CGTalk forum, I talked about the disadvantages of using the filein method...
