QT User Interface for 4K monitor and 1.5 scale factor
denisT.MaxDoctor
Advisor Advisor
Message 1 of 9
denisT.MaxDoctor
Is there a built-in solution to solve the problem of different scaling factor for 4K (high-DPI) monitors when working with Qt UI?
Replies (8)
Message 2 of 9
istan
Interesting question..
Never tested - but I hope it will autom. adjust it.
https://doc.qt.io/qt-5/highdpi.html
Message 3 of 9
denisT.MaxDoctor
That's the thing, that's exactly what's not working..... It looks like something on the 3DS MAX system side is blocking Qt High DPI support.
Message 4 of 9
istan
did you already check the beta board?
Message 5 of 9
denisT.MaxDoctor
beta board of what? max or qt?
I'm kind of not really sure what to complain about... I just don't see a clean way how to use the "UI scaling factor" when working with stylesheets.
Message 6 of 9
denisT.MaxDoctor
I haven't found a satisfactory solution to this issue yet, so I've temporarily halted or significantly minimized the use of Qt for the UI in my tool development.
Message 7 of 9
istan
I meant the max beta board. I was searching there and the answers I found, did not impress me much.
My personal conclusion after reading some threads is: Don't use scaling. For my application I recommend 2560x1440 monitors.
Message 8 of 9
denisT.MaxDoctor
  Haha... Unlike me, you can dictate to your clients which monitors to use and at what resolution. ☝️😎
Message 9 of 9
istan
They usually can't get anything out of Max without my software, so they have to accept my restrictions 🙄
