python set preferences values
haggi
Message 1 of 11
haggi
I'd like to set some scene preferences with python. e.g. turing autobackup on, setting the path for autobackup (if this is possible) and the name for autobackup, turing on compress on save and so on. Is this possible and if yes, how?
And I need a way to list all missing external files with python.
I aprecciate any help. Thanks.
Replies (10)
Message 2 of 11
drew_avis
Hi, it doesn't look like MaxPlus exposes this functionality directly.  You can get to the autosave settings via the MAXScript autosave interface through pymxs.  See http://help.autodesk.com/view/3DSMAX/2017/ENU/?guid=__files_GUID_B5405D51_E4D7_4448_9588_8D06B873578...
For example:
from pymxs import runtime as rt
autosave = rt.autosave
print "Autosave enabled? {}".format(autosave.enable)
print "Autosave filename: {}".format(autosave.filename)
Drew Avis
Content Experience Designer
Message 3 of 11
haggi_master
Very cool, thanks a lot. This will help. And a very similiar question:
I've tried to set the "Reference Coordinate System" in the toolbar to "World". With maxscript it works fine:
toolMode.coordsys #world
but the same in python:
pymxs.runtime.toolMode.coordsys("#world")
causes an error:
Traceback (most recent call last):
  File "<console>", line 1, in <module>
RuntimeError: MAXScript exception rasied.
-- Runtime error: Illegal coordsys mode type: "#world"
Any ideas?
Message 4 of 11
drew_avis
You just need to cast the MAXScript name value as a pymxs.runtime.Name:
pymxs.runtime.toolMode.coordsys(pymxs.runtime.Name("world"))
Drew Avis
Message 5 of 11
haggi_master
Great thanks a lot, I'll try it.
Message 6 of 11
haggi_master
Works fine, great. Now I can set the toolMode.coordsys, but how can I query it? A simple:
cs = rt.toolMode.coordsys()
results in an error message, it needs an argument. Any ideas?
Message 7 of 11
drew_avis
Try:
cs = pymxs.runtime.getRefCoordSys()
toolmode.coordsys() only sets the value.
Drew
Drew Avis
Message 8 of 11
Is there a way through pymxs to use the coordsys on a node and apply a transform?
Message 9 of 11
drew_avis
Pymxs does not expose the "in coordsys" context expression, but transforms on the node should be in the node's local coordsys.  Here's a simple rotate on a box:
b = rt.box()
a = rt.angleaxis(20.0, rt.Point3(0,0,1))
rt.rotate (b, a)
 This will produce the same result no matter what the toolMode setting is.
Does that answer your question?
Drew
Drew Avis
Message 10 of 11
I wish that was an option the only way I can zero out the parent coodsys is using an eval. Was hoping to do achieve the same thing using pymxs.
MaxPlus.Core.EvalMAXScript("coordsys parent $'%s'.pos = Point3 0 0 0" % node_name)
MaxPlus.Core.EvalMAXScript("coordsys parent $'%s'.rotation = Quat 0 0 0 1" % node_name)
Message 11 of 11
michaelsonbritt
In PyMXS, any MaxScript constant value, starting with a # character, is considered a pymxs.runtime.Name object, which is constructed from a string without the # character.  Specifically:
import pymxs
mxs = pymxs.runtime
mxs.toolMode.coordsys( mxs.Name( "world" )  )
A little late to the party here, but in case anybody else stumbles on this ...
Michaelson Britt
