'FBX file is empty' error message
Message 1 of 1
Hello, so I recently got 3DS Max 2016 and have been experiencing a problem with link FBX.
Basically I have exported an FBX from Lightwave, and imported it into Max as a link FBX. This works fine.
However when I adjust and re-export the FBX file from Lightwave, and try to reload it, I get the error message 'FBX file is empty'.
I found the following thread regarding a similar problem, but I'm not entirely sure if it resolves my issue, as they are discussing revit fbx exports.
https://forums.autodesk.com/t5/3ds-max-forum/link-revit-fbx-file-empty/td-p/5624447
Any suggestions as to where the problem lies? Is it possibly because I'm exporting the fbx from Lightwave, a non autodesk product?
Colin
Replies (0)
