polyop.setMapVert not work
Currently,i try to make a UV align tools,when i use polyop.setMapVert to change uv point position,it does not work.
even i try to polyop.setMapVert $ 1 0 [0,0,0],there was nothing change at all.
any help?
Thanks!
  • UV
Swordslayer
First, you cannot set a 0-index map vertex, maxscript indexing starts with 1. Second, in your code you use in one branch verts selected in unwrap modifier - why would you use polyop.methods after that (since that won't update/change unwrap at all, only the baseobject) and not unwrap methods instead?
